Hi, everybogy
I created a simple example project consist of only one source code file main.c, within Keil MDK 3.24 Eval as below.
#include <lpc23xx.h>
unsigned int variable0 __attribute__((section("sec_data"), used)) = 0x55AA55AA;
int main (void) { unsigned int i;
while (1) { i++; } }
// End of File
And when I compiled and linked the example using a scatter loading descrption file, one warning feedback produced by the linker read like this.
"Prj1.sct(14): warning: L6329W: Pattern *.o(sec_data) only matches removed unused sections."
The warning message above showed that the section sec_data had been removed by linker for the reason of no refered by the source code explicitly.
The scatter description file causing the warning read as below
LR_IROM1 0x00000000 0x00080000 {
ER_IROM1 0x00000000 0x00080000
*.o (RESET, +First)
*(InRoot$$Sections)
.ANY (+RO)
TABLE 0x40000000 0x20
*.o(sec_data)
RW_IRAM1 0x40001000 0x00001000
.ANY (+RW +ZI)
How can I restain the unrefered variable variable0 in the last image? Please give your hand!
make your variable volatile or static?
I have tried following three combinations, but get the same feedback from linker in the top post.
static volatile unsigned int fluke __attribute__((section("sec_data"), used)) = 0x55AA55AA;
static unsigned int fluke __attribute__((section("sec_data"), used)) = 0x55AA55AA;
... but could it be that you also need to somehow specify the section as "used"...?
Might you tell us why it is important that the variable is unused?
And what is the magic with 0x55aa55aa?
The attribute used is telling the compiler that this variable is used somehow and that it is not supposed to omit it in the object.
The linker still has no clue and removes it if unreferenced.
This
TABLE 0x40000000 0x20 { *.o(sec_data, +FIRST) }
will take care of it.
Regards Marcus http://www.doulos.com/
to : Per Westermar and Andy Neil
According to Chapter4.5 in Compiler Reference Guide(ARM DUI 0348A) from ARM, the attribute declaration part '__attribute__((section("sec_data"), used))' was used to inform the C compiler not ignore variable0 when compiling, even though it is not refered in source code explicitly.
The magic value 0x55AA55AA was used for convenient check in memory watching window when debugging.
Yes - that was what I was guessing at!
Note that there is a --keep option:
http://www.keil.com/support/man/docs/armlink/armlink_cchhhghb.htm
Sure. But then there'd be three places to properly set up the variable (code, scatter, cmd line). If a scatter file is used anyway, I'd prefer putting the information there.
Would it not be simpler to just provide a reference to it?
Or, can you put it in a section with other stuff that is referenced?
Which brings us back to the question: why is it there if it's not referenced?
Ah - so now we're training the trainers...?!
Oops; sorry - thought that was the OP.
I can thoroughly recommend Doulos as competent trainers!
What are you returning as 'int' from the function?
Maybe returning lint?
