Hello guys;
I have been working on UART0 setup of LPC2132 for a long time. I have achieved anything yet.Once I loaded a wrong pll setting and put the uc to death.I couldn't reload the correct settings via ISP. Yet, I changed the uc and here I am...However,I am totally confused.
Please do me a favor and send me a code.I use 14.74546Mhz xtall.
Thanks a lot...
start by reviving it - Keil's knowledge base will show you how to delete the entire flash using uv3. you may not need to setup the PLL at all - have you checked in the documentation what setting your chip uses if left along at startup? then look at the massive amounts of sample code made available by your tool chain!
