Hi, I'm using LPC2378,Fcclk=57.6MHz, Fcco=288MHz. I have 2 problems.
Problem 1: Cannot execute two IAP functions at a time.
IAP_Command(PREPARE_SECTORS, SECTOR_27, SECTOR_27,0,0);
works and returns a zero but
IAP_Command(ERASE_SECTORS,SECTOR_27,SECTOR_27,57600,0);
will not work in conjunction with the above function.The program aborts/crashes.
If I execute only
then it will return status code 9 (Sectors not prepared for write operation)
Problem 2: If I execute
IAP_Command(COPY_RAM_TO_FLASH,dest_flash_addr,source_ram_addr, 265, 57600);
after
then it will return status code 0x0D which does not exist.
Can anyone tell me what/where is the problem. Is there any code reference anywhere on the web that clearly describes step by step the IAP programming procedure?
Thank you in advance for all the help.
Pinto.
Sorry. The subject is LPC2378 IAP problems.
