I have a startup file for Realview compiler and i have to convert this startup file for GNU compiler.. Can sumbody guide me dat how shud i start all this... I am new to this field.....
"Can sumbody guide me dat how shud i start"
Note that GCC is not a Keil product - so this isn't really the right place to be asking.
You will need to read the GNU Manuals to find out what the GNU Compiler requires of its startup files.
For specific information about the GNU tools, start here: http://gcc.gnu.org/
The GCC Documentation is available online here: http://gcc.gnu.org/onlinedocs/
You will also need to read the manufacturer's datasheet for the particular chip that you intend to use.
I got ur point................ Thanx a lot...........
