AT91SAM9260 unexpected SPI behavior
I got some problems using SPI. I use the following code:
#include <AT91SAM9260.H>                /* AT91SAM9260 definitions            */
#include <lib_AT91SAM9260.h>            /* Library function definitions       */
int main (void) {
        // configure I/O lines for SPI
        AT91F_SPI0_CfgPIO();
        // configure PMC to enable SPI clock
        AT91F_SPI0_CfgPMC();
        // configure SPI mode
        AT91F_SPI_CfgMode(AT91C_BASE_SPI0, AT91C_SPI_MSTR);
        // configure chip select registers
        AT91F_SPI_CfgCs(AT91C_BASE_SPI0, 0, AT91C_SPI_CPOL | AT91C_SPI_BITS_16 | (AT91C_SPI_SCBR * 10));
        // switch to the right PCS
        AT91F_SPI_CfgPCS(AT91C_BASE_SPI0, 0);
        // configure AIC for using SPI interrupt
        AT91F_SPI_Enable(AT91C_BASE_SPI0);
        while (1)
                AT91F_SPI_PutChar(AT91C_BASE_SPI0, 0x8F, 0);
SAM9260.s, retarget.c were included.
Now the problem:
When running form external RAM with optimization Level 0 there is not data on the SPI-line (measured with an oscilloscope). And the SPI-registers are set to different values. (A memory dump can be attached if needed. )
In any other configuration (other optimization level or from internal RAM) there are no problems.
Can someone reproduce the problem?
Can someone give a solution?
Many thanks,
Stefan
