I haven't found this: I would like to be able to JUMP in the viewer to a break point while NOT debugging. IE just go to where the break point is set in ones code.
The other question is HOW do I set a book mark in a file that I can jump to later? I have to scroll there code sometimes so I can check variables etc. There appears to be no book mark ability. For editing this would be very handy.
Stephen
Hello Stephen,
1) You asked: "...how do I set a book mark in a file?"
You can set a bookmark on any line of code with the Ctrl+F2 shortcut:
http://www.keil.com/support/man/docs/uv3/uv3_ui_edit.htm
The bookmarks will remain in editor mode or debug mode.
2) You also asked: "...so I can check variables etc" "
The traditional way to do this is to right click on the global variable and select "Add ... to watch window..." and choose either window 1 or 2.
Then go to View -> Watch and Call Stack window" and you will be able to continuously watch a set of Global variables. Choose the tab at the bottom of the watch windows to switch between different lists. See:
http://www.keil.com/support/man/docs/uv3/uv3_db_dbg_watchwin.htm
There is not an easy way to jump back and forth between breakpoints; bookmarks were designed for that role.
Thank you I wonder why I could find a reference to that? In any case your answers are too the point thanks again.
Stephen R. Phillips
