Keil says to me, that any USB-Register is undefined. Now it's impossilbe for me to show if they're correct or not.
How can I solve this Problem???
Every other SFR in the LPC2368 is alright. But on USB-Files I'm receiving Error34.
greetings
Not much context in your post.
Has Keil support said something? Or are you thinking about an error message from the Keil compiler? Or an error message from a call to any Keil RTL function relating to USB?
If you are talking about the SFR definitions for the USB controller, then it is simple for you to check. Compare the contents of the header file with the datasheet.
But for people to be able to help, you really have to tell where you got a "Error34". The more context you supply, the quicker and better answer you may receive.
Indeed!
You're right! A little bit more content could be usefull!!
My Problem is, that I'm unable to read some SFR's. For Example the whole USB-Registers in my LPC2368.
Is it true, that the USB-Periphel-SFR's are located the same way like A/D-Converter for Example???
Under PERIPHELS in the normal IDE???
greetings from germany
