Serial interrupt of AT89C51RE2 doesn't work with uVision3
Hello all,
For a home project I use the AT89C51RE2. I wrote some C code with Keil uVision3 to have this micro respond to serial interrupts via UART0.
I used the internal baudrate generator and set it to 9600 baud.
The interrupt function is something like: void call_ISR(void) interrupt 4.
When using the uVision debugger/simulator, the debugger goes to the interrupt handler on a simulated interrupt. So far so good.
Arriving at the code line with 'SBUF_0' the next step the debugger goes to the end of the interrupt handler and the content of SBUF_0 will not be read!
What could be the cause of this??
Any help i will appreciate!
Max
