Hello. I've a problem with LPC2103. I've two boards. The first-one is a Silica Demo Board with a Philips (with Philips logo) LPC2103. The second one is a home built board with only a NXP (note not Philps marked!) LPC2103 and just supplies and xtal.
I've a Keil uLink and I use uVision3 for Arm. So, I can program both MCUs and everything works well. Unfortunately I can debug just only the Silica demo boards, on my home built board doesn't work. If I put the MCU in run mode the program doesn't go; if I put a breakpoint the program doesn't stop. With Silica board I can do all of these operations.
I checked the layout and all board connections are correct respect to the schematic of jtag connector of uLink (got on Keil web site).
I sniffed all JTAG net and I didn't see any suspectous signal. No noise.
I pushed the power supply of core to 2.0V on my board like Silica board after reading an errata from NXP regarding a bonding dropout voltage....nothing appened.
May be a problem because I'm using an NXP marked MCU instead of a Phlips marked MCU? I didn't find any note regarding mask errata or similiar (silicon problem).
Can anyone help me?
Best Regards
Stefano
The NXP-marketed chips are the chip that was earlier Philips-marketed. They have just splitted of a lot of components to a subsidary running with a different name.
Similar to Motorola processors switching name to Freescale.
One advantage with a neutral name is that a competitor to Philips may use the processor without people pointing finger.
And are there no differences in the silicon mask?
Regards Stefano
Processors have steppings. If you look in the Errata sheet, you can see a list of the known issues with different steppings.
But steppings does not have anything to do with the name change to NXP.
