I'll use one timer for eight different events (with different values). If a event happened, the value of the variable will be increased.
variable1++ if 2x timer value will be increased variable2++ if 5x timer value will be increased
and so on.
Is that possible to do that without the use of a ISR?
The main program will ask for the value of the variable1, variable2 - it is only important if the value of the variable1 e.g. is greater than one defined value - not if the value of the variable1 = defined value.
best regards Bernd
