MDK 3.02a to MDK 3.10
I started a project with MDK 3.02a using STR71x microcontroller.
Now, cause stack problems, I must use MDK 3.10 where these problems are solved.
I use newer RTL_Config.c and STR71x.s, but my software jump to os_idle_demon.
Anyone have this problem?
What must I change passing from MDK 3.02a to 3.10?
