please guide me how to program the P89V51RD2 from keil ide it self. I have used Flash magic's command line version FM.exe but it looks like i have some problem in the way i configure it.
If there is any another method please let me know.
Thanks, Mihir
P89V51RD2 Flash Programming from keil I have used Flash magic's command line version FM.exe but it looks like i have some problem in the way i configure it. If there is any another method please let me know. This sounds as if you are trying to program via FM through the Keil IDE?
If that is so, skip the IDE and get the programming to work using FM only (help avaialable at the FlashMagic forum). Then and only then you can try integarting it.
BTW what is so horrible about it not being integrated?
PS i have some problem ... is any another method Bad, bad idea. If you, every time you have a problem, look for another method, your troubleshooting skills will never improve. Get what you are trying to do to work, before looking for other methods. Of course, there are cases where the original idea is so bad that 'another method' is the only way out, but with the many people using FM this is not one of them.
