Hi, can anyone tell me why i never see anything in the call stack window (watches), i expect to see the function calls as i debug and step into functions but nothing is shown. can anyone help?
I know that the call stack is used when running a simulation (no read hardware, all in the computer).
I don't think it's used when doing remote target debugging (serially, with the monitor). I don't see how could the monitor get that information efficiently anyway.
That holds true for code coverage and a few other things as well.
An ICE (in circuit emulator) doesn't have those limitations.
$0.02
The debugger should be able to fetch and decode the stack information just the same as a normal PC debugger does it.
As long as the code doesn't have too high optimization, each function call will produce a normal stack frame that the debugger can walk backwards in. Then it is enough to lookup the return addresses to figure out which function the return addresss points to.
Obviously, a debugger normally don't try to touch the stack of a running target - the target changes the stack much too often for it to be worth it.
That's true only as long as the function performs no PUSHes and POPs while running. Those can make it quite a task to find the return address among all that other stuff on the stack.
Which is also a reason why most processors (with support for a "real" stack) has a link or base-pointer register to allow constant access to its auto variables and to its parameters. The situation is definitely bleak for processors that only has a return stack and have to simulate a parameter stack. Then it is up to the compiler to decide if it will simulate such a register - at least for debug builds.
