I have compiled and ran the KEIL example program 'RL-ARM SD/MMC File Demo for MCBSTM32' (mcbstm32_sd_file.zip) and there is no problem.
As I tried to port the code to my own uvision project, I could read the SD card directory and do, say, file rename 'REN'. However the program crashed if I run the TYPE command. The problem seems to be in the fgetc() call in cmd_type(). Similarly the program would crash if I execute a COPY command.
Can you give me some indication as to what might be the cause? I am using MDK-ARM 3.15b and RL-ARM 3.13a.
Thanks and best regards,
Steven
Problem solved. The heap size was too small. As I increase the heap size from 0x200 to 0x800, the program works.
