How can i get more ram memory
i want to build a kind of soundbox-toy.
It has grown so i need a few more extra bytes of RAM memory.
Unfortunately the printed circuit board is ready.
So i can not add some external memory.
It is allowed to modify the startup.s file?
Reducing stack to get a little more memory?
How to test out the limits?
Can i do this at all?
I'am worried a little, all this stuff in the startup file looks very complicated to me. Afraid of doing the wrong things!
I'am using a ADuC7026 it has only 8 kByte of RAM memory.
Here's my startup.s file
        Mode_USR  EQU      0x10
        Mode_FIQ  EQU      0x11
        Mode_IRQ  EQU      0x12
        Mode_SVC  EQU      0x13
        Mode_ABT  EQU      0x17
        Mode_UND  EQU      0x1B
        Mode_SYS  EQU      0x1F
        I_Bit     EQU      0x80    /* when I bit is set, IRQ is disabled */
        F_Bit     EQU      0x40    /* when F bit is set, FIQ is disabled */
        UND_Stack_Size  EQU     0x00000004
        SVC_Stack_Size  EQU     0x00000004
        ABT_Stack_Size  EQU     0x00000004
        FIQ_Stack_Size  EQU     0x00000004
        IRQ_Stack_Size  EQU     0x00000080
        USR_Stack_Size  EQU     0x00000400
AREA   STACK, DATA, READWRITE, ALIGN=2
        DS   (USR_Stack_Size+3)&~3  ; Stack for User/System Mode
        DS   (SVC_Stack_Size+3)&~3  ; Stack for Supervisor Mode
        DS   (IRQ_Stack_Size+3)&~3  ; Stack for Interrupt Mode
        DS   (FIQ_Stack_Size+3)&~3  ; Stack for Fast Interrupt Mode
        DS   (ABT_Stack_Size+3)&~3  ; Stack for Abort Mode
        DS   (UND_Stack_Size+3)&~3  ; Stack for Undefined Mode
Top_Stack:
// MMR definitions
        MMR_BASE        EQU     0xFFFF0000      ; MMR Base Address
        REMAP_OFFSET    EQU         0x0220
        PREMAP_OFFSET   EQU         0x0224
        POWKEY1_OFFSET  EQU         0x0404
        POWCON_OFFSET   EQU         0x0408
        POWKEY2_OFFSET  EQU         0x040C
        PLL_SETUP       EQU     1
        PLLCFG_Val      EQU     0x00000000  // alter Wert war 0x00000001
        GPIO_SETUP      EQU     1
        GPIOBASE        EQU     0xFFFFF400
        GP0CON_Val      EQU     0x00000000
        GP1CON_Val      EQU     0x00000000
        GP2CON_Val      EQU     0x00000000
        GP3CON_Val      EQU     0x00000000
        GP4CON_Val      EQU     0x00000000
$IF (RAM_INTVEC)
// Exception Vector Area in RAM
AREA   VECTORS, DATA, AT 0x00010000
                DS      64
$ENDIF
// Startup Code must be linked at address which it expects to run.
AREA   STARTUPCODE, CODE, AT 0x00080000
       PUBLIC  __startup
       EXTERN  CODE32 (?C?INIT)
__startup       PROC    CODE32
// Pre-defined interrupt handlers that may be directly
// overwritten by C interrupt functions
EXTERN CODE32 (Undef_Handler?A)
EXTERN CODE32 (SWI_Handler?A)
EXTERN CODE32 (PAbt_Handler?A)
EXTERN CODE32 (DAbt_Handler?A)
EXTERN CODE32 (IRQ_Handler?A)
EXTERN CODE32 (FIQ_Handler?A)
// Exception Vectors
// Mapped to Address 0.
// Absolute addressing mode must be used.
Vectors:        LDR     PC,Reset_Addr
                LDR     PC,Undef_Addr
                LDR     PC,SWI_Addr
                LDR     PC,PAbt_Addr
                LDR     PC,DAbt_Addr
                NOP                            /* Reserved Vector */
                LDR     PC,IRQ_Addr
                LDR     PC,FIQ_Addr
Reset_Addr:     DD      Reset_Handler
Undef_Addr:     DD      Undef_Handler?A
SWI_Addr:       DD      SWI_Handler?A
PAbt_Addr:      DD      PAbt_Handler?A
DAbt_Addr:      DD      DAbt_Handler?A
                DD      0                      /* Reserved Address */
IRQ_Addr:       DD      IRQ_Handler?A
FIQ_Addr:       DD      FIQ_Handler?A
// Reset Handler
Reset_Handler:
// Setup PLL
IF (PLL_SETUP != 0)
                LDR     R0, =MMR_BASE
                MOV     R1, #0x01
                STR     R1, [R0,#POWKEY1_OFFSET]
                MOV     R1, #PLLCFG_Val
                STR     R1, [R0,#POWCON_OFFSET]
                MOV     R1, #0xF4
                STR     R1, [R0,#POWKEY2_OFFSET]
ENDIF   ; PLL_SETUP
// Setup Pins
IF (GPIO_SETUP != 0)
                            ADR     R10, GPIO_CFG          /* Pointer to GPIO CFG */
                LDMIA   R10, {R0-R5}           /* Load GPIO Configuration */
                STMIA   R0, {R1-R5}            /* Store GPxCON */
                B       GPIO_END
GPIO_CFG:       DD      GPIOBASE
                DD      GP0CON_Val
                DD      GP1CON_Val
                DD      GP2CON_Val
                DD      GP3CON_Val
                DD      GP4CON_Val
GPIO_END:
ENDIF   ; GPIO_SETUP
// Setup Stack for each mode
                LDR     R0, =Top_Stack
// Enter Undefined Instruction Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_UND|I_Bit|F_Bit
                MOV     SP, R0
                SUB     R0, R0, #UND_Stack_Size
// Enter Abort Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_ABT|I_Bit|F_Bit
                MOV     SP, R0
                SUB     R0, R0, #ABT_Stack_Size
// Enter FIQ Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_FIQ|I_Bit|F_Bit
                MOV     SP, R0
                SUB     R0, R0, #FIQ_Stack_Size
// Enter IRQ Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_IRQ|I_Bit|F_Bit
                MOV     SP, R0
                SUB     R0, R0, #IRQ_Stack_Size
// Enter Supervisor Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_SVC|I_Bit|F_Bit
                MOV     SP, R0
                SUB     R0, R0, #SVC_Stack_Size
// Enter User Mode and set its Stack Pointer
                MSR     CPSR_c, #Mode_USR
                MOV     SP, R0
// Enter the C code
                LDR     R0,=?C?INIT
                TST     R0,#1       ; Bit-0 set: main is Thumb
                LDREQ   LR,=exit?A  ; ARM Mode
                LDRNE   LR,=exit?T  ; Thumb Mode
                BX      R0
                ENDP
PUBLIC exit?A
exit?A          PROC    CODE32
                B       exit?A
                ENDP
PUBLIC exit?T
exit?T          PROC    CODE16
                B       exit?T
                ENDP
                END
