Hello all, I guest this issue has something to do with integer promosion or something related but still I don't fully understand this: I have 2 unsigned long integers containing an equal value. However, when I compare them the program behaves as if they are not.
if ( (l_x - l_y) == 0) 4640 ?LINE 939 0EFC 20C6 4641 SUB R12,R6 R 4642 ?SYMB '',$,102,2 0EFE 30D7 4643 SUBC R13,R7 0F00 70CD 4644 OR R12,R13 0F02 3D15 4645 JMPR cc_NZ,_217
what is happening? it must be related to the numbers being 32 bit long.
Thanks in advance Cactus Blip
Are you sure that the register pairs R13:R12 and R7:R6 have the same value immediately before executing line #4641 ? Not sure how Tasking assigns registers and deals with unsigned longs - the code snippet looks ok.
Thanks for your reply. well, I did my comparison in 2 parts - 16 bits each. That is good enough for now.
