I'm using SDRAM with AT91SAM7SE. My problem is that even though the processor's MCK(Main clock) can go up to max 96 MHz but the SDRAM clock can only go up to 48 MHz.
Processor can be run at 96 MHz only if internal flash and Ram are used.
So is its the limitation of the Atmel?
