*** FATAL ERROR L210: I/O ERROR ON INPUT FILE:
*** FATAL ERROR L210: I/O ERROR ON INPUT FILE: EXCEPTION 0021H: PATH OR FILE NOT FOUND FILE: E:\RAJESH\SETUPTKEY_VERIFYMAY07\SIMULATION_WITHCASON.OBJ
I am getting the above error while building the code. I have read previous threads on this error and found that the object file mentioned above in the error may be missing out. But in my case, the object file was there when I created this C file and compiled/built last month in previously installed SiLabs and KEIL IDE. Again I reinstalled this SiLabs IDE and trying to compile/build this file without changing anything, but this time it is showing error. And also, while trying to do this, the object file which was created last time got deleted.
I am using the follwing versions :
C51 COMPILER V7.20
BL51 BANKED LINKER/LOCATER V5.11
SiLabs IDE Version 2.91
Can someone help me on this?
