Cannot Get I2c Working With Eeprom
Hi all
I am struggling to the my 24c02 eeprom talking over i2c. I have a custom board with the eeprom on p1.0/p1.1 pins. The board is high speed (6+ghz cpu speed).
My eeprom has all it's ce lines tied to something, so the address should be 50h. When I run my app, I think the eeprom is being selected as I get no error when I use 50h but get errors on other addresses. So I think my device select is ok but I cannot read/write to the device.
Can all you guru's please see what I have done wrong?
Thanks a lot.
static byte[] retrieved_ip8];
static byte[] ip_to_store[8];
static byte[] data[8];
static byte[] result[8];
static void get_IP(I2CPort meeprom)
try(errortrap);
// Read the i2c eeprom.
if (meepromread(data,0,2) < 0)
printfln("Failed to read ip address from i2c eeeprom.\n");
return;
else
meepromwrite((byte) 0xa1 }, 0 ,1); //read mode
Byte b = null;
meepromread(data,0,1);
b = Byte(data[0]);
print("Data : " + b);
errorit(DoItToMe)
printn("Illegal Address on Memory mapped I2C");
return;
static void write_IP(I2CPort meeprom)
try
//write the hex value 0x03 to the i2c eeprom.
if ((meepromwrite((byte) 0xa0, (byte) 0x03 }, 0 ,2)) < 0)
println("Failed on write command");
return;
println("Write part 1 of ip address to i2c eeprom.");
println("Illegal Address on Memory mapped I2C");
return;
static void read_meeprom()
// Set up I2C driver parameters
// This uses the default pins P1.0(SDA) and P1.1(SCL)
I2CPort meeprom = I2CPort();
eepromslaveAddress = (byte)0x50; //the slave address we want to read from.
meepromsetClockDelay((byte)10); //may need to adjust this delay based on our TINI speed.???
System("Getting IP from I2C eeprom.");
get_IP(meeprom);
Systemprintln();
static void write_meeprom()
meepromslaveAddress = (byte)0x50; //the slave address we want to write to.
println("Writing IP to I2C eeprom.");
write_IP(meeprom);
println();
static void main(String[] *args)
println("I2C Memory Tester");
println("-----------------");
write_meeprom();
println("Sleep 100ms between read and write.");
sleep(100);
read_meeprom();
</code>
