I'am using RL ARM Flash Filesystem V3.13 on Atmel AT91SAM7S256 processor. In the following example Reading a File (with 3 characters) the feof function reads everytime 4 characters.
here is my test programm:
void TestFsEof(void) { #define FNAME "F:Tst.bin" FILE *fout, *fin; // Write fout = fopen (FNAME, "w"); if (fout != NULL) { char Car = 'A'; for (int cnt=0; cnt<3; cnt++) { fwrite (&Car, sizeof(Car), 1, fout); Car++; } fclose (fout); } fin = fopen (FNAME, "r"); if (fin != NULL) { int RecNr = 0; char Car = 0; u32 Result; while (!feof (fin)) { Result = fread (&Car, sizeof (Car), 1, fin); //if (Result < 1) // break; // Checking EOF does not work, so i must check the Result from fread() TRACE(("\n\rRecNr:%d Car:%c", RecNr, Car )); RecNr++; } fclose (fin); } }
Thank you for any replies. Eugen
From the manual:
The feof function returns a nonzero value after the first read operation that attempts to read past the end of the file. It returns 0 if the current position is not end of file. There is no error return.
Your example works correctly according to the manual, but your code is wrong. Here is a modified code:
fin = fopen (FNAME, "r"); if (fin != NULL) { int RecNr = 0; char Car = 0; u32 Result; while (!feof (fin)) { Result = fread (&Car, sizeof (Car), 1, fin); TRACE(("\n\rRecNr:%d Car:%c", RecNr, Car )); RecNr += Result; } fclose (fin); }
