Hi guys,
I am currently using the C51 Evaluation Software for compiling C code but the evaluation version has a 2K size limitation for the object code generated. What should I do to upgrade to a version without the 2K size limitation? Is the upgraded version for that evaluation software called CA51 Compiler Kit? Thanks a lot guys.
Regards, Siang
To get rid of the limitations of the evaluation version, you will have to buy the commercial version.
http://www.keil.com/c51/selector.asp
www.keil.com/.../prices.asp
http://www.keil.com/company/contact.asp
