On program for the TI CC1110, the IAR is the default development IDE, the IAR use the specified link configuration file to process the memory map. I think there must be the same mechanism for Keil. I think the startup.a51 is can do this kind of settings, I have modified one startup.a51 file, but not aids!
You can test the memory map problem on CC1110 by the following project:
unsigned long SumValue( unsigned long X, unsigned long Y ) {
return X+Y; }
void main() {
unsigned long iRetVal;
iRetVal = SumValue( 100, 16 );
If the memory map is correctly set, the iRetVal will be 116, otherwise a very large magic value!
Appendix below is the link configure file for IAR, how should I modify my startup.A51 file upon the standard template?
Thanks & Best Regards
Appendix: link configure file for IAR ( CC1110 from chipcon )
//////////////////////////////////////////////////////////////////////////////// // // File: lnk51ew_cc1110.xcl // Date: 2007.3.26-8:44 // // Description: // This is a extended command line file for XLINK tool to be used when // debug applications written for the Chipcon CC1110. // // Important: // Data cannot be located at address zero, this address is reserved for // the null pointer. // ////////////////////////////////////////////////////////////////////////////////
//////////////////////////////////////////////////////////////////////////////// // // Variables (used by lnk_base.xcl) // ================================ // // Segment limits // -------------- // // // IDATA // -D_IDATA_END=0xFF // Last address of Idata memory // // // PDATA // -D_PDATA_START=0xF000 // First address for PDATA memory. -D_PDATA_END=0xF0FF // Last address for PDATA memory. // // // // // IXDATA // -D_IXDATA_START=0xF000 // The internal xdata is 4k. -D_IXDATA_END=0xFDA1 // FDA1 to FEFF used for reg savings (350 bytes) // FF00 to FFFF mapped to IDATA // // // XDATA // // The internal XDATA is used as XDATA. -D_XDATA_START=_IXDATA_START -D_XDATA_END=_IXDATA_END // // // CODE // // Code size: -D_CODE_START=0x0000 -D_CODE_END=0x7FFF // 32KB code // // // NEAR CODE // -D_NEAR_CODE_END=_CODE_END // Last address for near code. // // // TINY CODE // -D_TINY_CODE_END=0x7FF // Last address for tiny code. // // // // Special SFRs // ------------ // // // CODE bank setup // -D_FIRST_BANK_ADDR=0x10000 -D_NR_OF_BANKS=0x00 // // // Register bank setup // -D?REGISTER_BANK=0 // Default register bank (0,1,2,3). -D_REGISTER_BANK_START=0 // Start address for default register bank (00,08,10,18). // // // PDATA page setup // -D?PBANK_NUMBER=F0 // High byte of 16-bit address to the PDATA area. -D?PBANK=93 // Most significant byte in MOVX A,@R0. (0x93 is sfr MPAGE). // // // Virtual register setup // ---------------------- // -D_BREG_START=0x00 // The bit address where the BREG segments starts. // Must be placed on: _BREG_START%8=0 where _BREG_START <= 0x78. -D?VB=0x20 // ?VB is used when referencing BREG as whole byte. // Must be placed on: ?VB=0x20+_BREG_START/8. // ////////////////////////////////////////////////////////////////////////////////
//////////////////////////////////////////////////////////////////////////////// // // To the reader: Ignore this section ------------------------------------------ // // // Dummy definitions needed to satisfy lnk_base.xcl // // -D_FAR_DATA_NR_OF_BANKS=0x0E // Number of banks in far data memory. -D_FAR_DATA_START=0x010001 // First address of far memory. -D_FAR_DATA_END=0xFFFFFF // Last address of far memory. -D_FAR_CODE_START=_CODE_START // First address for far code. -D_FAR_CODE_END=_CODE_END // Last address for far code. // ////////////////////////////////////////////////////////////////////////////////
//////////////////////////////////////////////////////////////////////////////// // // Include the lnk_base command file // ================================= // // -f lnk_base.xcl // ////////////////////////////////////////////////////////////////////////////////
//////////////////////////////////////////////////////////////////////////////// // // Chipcon device specific // ======================= // // // // // ////////////////////////////////////////////////////////////////////////////////
