Hi
I am doing project on LPC2106 (Keil C), my application is I want generate the different duty cycle PWM pulses using LPC2106 PWM channel I read data sheet but I confused with PWM registers configuration
Please provide me one example code for 70% duty cycle PWM pulse generation using LPC2106(crystal frequency is 12MHz).
Thank you
Regards
akthi
NXP has a full code bundle supporting example code for this device including PWM programming. I suggest that you go to the http://www.nxp.com and search for the code bundle for the LPC21xx devices. Bradford
Hay
Thank for the reply I am not clear with keil example code Please provide some tutorial recording how to generate 70% duty cycle 1KHz PWM wave How to calculate match register values for 70% duty cycle, using crystal frequency is 14.7MHz
Regards akthi
I am doing project on LPC2129 (Keil C), my application is I want generate the different duty cycle PWM pulses using LPC2106 PWM channel I read data sheet but I confused with PWM registers configuration
