I need some advice on protecting the micro controller when measuring an AC power line (300VAC max). I do not have much experience in this matter.
My circuit is supplied with a fly-back switcher because of high power requirements. The supply to the micro controller is isolated.
I now want to measure the voltage, phase and freq at the input of the fly-back switcher (directly on the AC power line). I'm using a resistor and 2 clamping diodes to protect the I/O pin.
Is this enough protection? But the circuit is not isolated anymore, except on the switcher side.
How do I go about isolating the measuring part without using a transformer. Can I use an opto-coupler?
Or is it unnecessary to isolate the measuring part while the supply is isolated?
The circuit must conform to standards for commercial use (SABS - South African Bureau of Standards).
Please any good information will help.
Regards
what about a linear optocoupler, here is one piched at random for reference rocky.digikey.com/.../HCNR200_201.pdf
PS Digikey links tend to die if link is dead go to digikey, search optocoupler, click "Optoisolators, Transistor, Photovoltaic Output (4,310 items)" click linear
But how do I measure the voltage on the AC line?
I did a simulation with the opto coupler, but it seems like I can't measure the voltage across a resistor because the transistor inside the opto coupler is either switched ON or OFF.
So the transistor is either switched on, or switched off.
Did you notice the little word linear in Eriks post? Any guess what he might have meant with that? Maybe a linear opto coupler isn't digitally on/off, but have a linear response curve?
1) You're asking in the wrong place. That's a purely electronical problem. It is in no way particular to Keil, or even microcontroller programming in general.
2) If you don't have experience in this matter, keep your hands well away from it. 300 Volts will kill people if not handled properly --- do you want to be one of them, or worse yet, be responsible for such a thing happening to somebody else?
In short: if you must ask, you're not qualified to do this, and may be legally forbidden to try.
"if you must ask, you're not qualified to do this, and may be legally forbidden to try."
Especially given this - highlighted in the origianl post:
"The circuit must conform to standards for commercial use (SABS - South African Bureau of Standards)"
Protection and safety design of this kind is not something that one learn at Engineering School. It is something that one learn through experience in the industry.
I am by no means a novice to this kind of work and just asked for some ideas. Hopefully somebody with some experience could have given a useful input rather than putting me down (At least Erik did). Thanks!
I am qualified to do this and have 5 years experience in electronic design (Not that it is that much but it counts).
But thanks for your help, concern and positive responses.
Have you looked for a linear optocoupler yet?
