I've bought a sparkfun logomatic v1.0 to change reprogram as an advanced datalogger. There is a lpc2138 onboard and it is possible to program it with the lpc2000 flash utility.
I've tried to compile a test progam, just to blink some leds on P0.x but the processor seems to do only the first command. I believe there is somewhere a parameter in the compiler settings I've mist.
I set up for a lpc2138 changed the freq to 147.456 MHz, IROM from 0x4 to 0x7FFF, IRAM from 0x40004000 to 0x40007FFF just like detailed in the datasheet.
#include <LPC213x.H> void delayms(int j) { unsigned int i; unsigned int k; i = 0; k = 0; while (i != j) { k = 0; while (k != 14746) { k++; } i++; } } int main (void) { PINSEL0 = 0x00000000; IODIR0 = 0xFFFFFFFF; IOCLR0 = 0xFFFFFFFF; while (1) { IOSET0 = 0xFFFFFFFF; delayms(1000000000); IOCLR0 = 0xFFFFFFFF; delayms(1000000000); } };
Is there anything I'm missing? Thanks in advance, Ruben
If delayms() really gives a one-ms delay, then you are requesting a one-million-seconds long delay. That is almost 278 hours...
By the way, don't do busy-loops for delays. Initialize a timer and use instead.
147.456MHz - is that PLL frequency or the actual instruction frequency? Isn't 60MHz the highest allowed instruction speed for a 2138?
Especially not delays of many(!) hours!
:-0
I don't do that for normal, only for testing if this thing is working, and this stupid thing isn't.
It is a simple procedure I copied from another sample thing.
Greetings, Ruben
But have you verified that the processor frequency is within valid range - you claim 147MHz which is faster than the processor supports, unless you mean PLL.
Also, have you verified that your delay isn't so long that you don't see a blink?
Exactly what have you done to narrow your problem down?
"I don't do that for normal, only for testing if this thing is working, and this stupid thing isn't."
Are you sure?
As Per pointed out, your test could take 278 hours to complete - that's over 11 days!
It was indeed a problem of the frequency, I putted in 147 MHz, it was 14 MHz in reallity.
Now, I have only a problem that the arm does only a few times the while(1) cycle.
Thanks for the answers. Ruben
