How to connect 8051 as a slave device through I2C
Hi friends,
I have interfaced EEPROM and RTC with AT89C51 through I2C .Now i am trying to interface another AT89C51 as a slave device.In that i am having two issues
NO1:If I2C Bus needs any External Pull up Resistors ?
I am not having clear idea whether i can connect SDA(Serial Data pin) & SCL(Serial Clock pin ) directly to Master controller from Slave controller.Because while i am connecting EEROM i put 2.2k pull up resistor to SDA&SCL , also i know that in AT89C51 only P0 (port 0) is alone open collector. but here i am using P3 .
NO2:How to deal with I2C driver in Slave 8051?
Do u have any documents that how to write slave side program or web links.. for the same. because when i am searching i found plenty of documents only describing Master side programming. But i need details about slave side programming which is in Bit banking method.
Please share your experience and give good Web Links & Documents
Thanks & Regards,
Kirba
