Yes you might say
Do you have 2$?
if yes, go to small electronics shop and buy cheapest FM radio which contains this chip.
but i cannot and i must build the reveicer for narrow or wide modulation so i think an 8052 is the best option.
plz can anyone help me to make the hardest first step. i have never written any code and need to know where to start.
plz can anyone help me to make the hardest first step. i have never written any code and need to know where to start. first get rid of the uttely stupid SMS abbreviations it is spelled 'please' not "screw you" second decide if you want to do assembler or C third study "the bible" fourth regardless of second learn the '51 assembler fifth if you chose C in second learn C on the PC sixth work through the "getting started guide" seventh make a simple project eight make a slightly more complex project ninth ...
DO not skip any of the above steps, it will hurt you if you do.
with dilligence since you "have never written any code" you should be able to do something worthwhile in 2-6 months,
<quote> it is spelled 'please' not "screw you" <endquote>
que ??????
fyi it <bold>is<endbold> short for please
Learning programming is not trivial - in particular, it requires a great deal of attention to detail.
Did you not even notice in the preview that your <quote> and <bold> tags were not recognised by this forum?
Did you not notice that instructions for formatting Bold and Italic text are clearly given immediately above the box where you typed your message?
If you can't cope with simple instructions like this, you are going to find programming very trying!
only in the opinion of SMS idiots. What is wrong with using English.
If you entered your post from a cell[phone, it would be another story.
"i think an 8052 is the best option."
On what basis do you think that?!
AM/FM sound radio is analogue: how do you suppose that any digital device - like a microcontroller - will help?
MR BITEMAN,
Ok my friend u r a Good worker and i think u will be some thing in code word so i will give u what i have . this is the firest method . it is not a Pro but it work ...... requirement : it need some chance not else in some code u will find a ljmp (jnz , cjne) and the sjmp always hppen for some reason so after this sjmp the Code not do anything or lets say without avail as if not exist . ( SO U NOP THE JMP AND BEGIN WRITE UR CODE TILL BEFORE THE LINE OF THE JMP COMMAND go) so u can play there and put ur code there . mabye u say the byte will not enough . No my friend , i will say search for anthor place and make jmp to it and continue write ur code there . and goon i hope i have some time so i will make a movie explane it , but still busy in some project hope it work. in other word i try to collect a group for work to gather in Coding and something else ......hope i will !!!!! if u not understand it just PM and i will try to explain more .....by but some code example Ok no problem u can do it my friend and if there any problem just connect me. if u don't like the method wait for the next method it will be more complex but will work fine so be attention.. bye ur best friend
thx u 4 the kind adv rafid.
but i want to use the 8052. a pc can make sound bt is 2 big 4 me . i cnot put on my arm!!!!!!!!!!!!
Again, how do you think that this is going to implement an analogue AM/FM radio?!
jon said i can use the ariel on his roof to get the waves
I thought you said you wanted this thing on your wrist?!
Anyhow, once you've got the "waves" - which are, of course, analogue - how do you suppose that a digital microcontroller is going to deal with them??
... and I claim my $5!
congratulations.
see your prize at
new.media.aau.dk/.../phism.jpg
you will have to arrange collection
this forum is
"Not 4 ppl who do sms"
I GUESS the above would mean what I want to say
If you insist on using Stupid Monkey Shit do it elsewhere
just ignore it!
Competition time.
What erik is an acronym for?
