meaning of weak pull-ups
Hello, can anyone please explain me the purpose of weak pull-ups resistor of a port?
What are they used for?
thanx in advance,
M.
  • On one hand, you don't want open inputs. A floating input can result in a very high current consumption.
    The reason for the pull-up to be weak is that external electronics can override it, i.e. it doesn't take much current to draw the input low.
    On the other hand, you can combine a weak pull-up resistor with an open-collector (or open-drain) transistor and get a pin that may be used as both input and output. If the transistor is activated, the signal may drain a lot of current, driving LEDs or other current-consuming equipment. If the transistor is deactivated, external equipment can set the pin high or low, i.e. the processor can use the pin as an input.
  • wow, pretty fast and clear reply. thanks for that.
    regards M.
