nested interrupts
hi,
Am using LPC2366.From the keil sample software i took two macros IENABLE and IDISABLE and their definitions,used in ISR routine as in sample code.But my software hangs at PAbt_Addr DCD PAbt_Handler.what is the reason?
  • keshan,
    Can you please post relevant code?
  • // Macro for enabling interrupts, moving to System mode and relevant stack operations
    #define IENABLE /* Nested Interrupts Entry */ \
    __asm { MRS LR, SPSR } /* Copy SPSR_irq to LR */ \
    __asm { STMFD SP!, {LR} } /* Save SPSR_irq */ \
    __asm { MSR CPSR_c, #0x1F } /* Enable IRQ (Sys Mode) */ \
    __asm { STMFD SP!, {LR} } /* Save LR */ \
    // Macro for disabling interrupts, switching back to IRQ and relevant stack operations
    #define IDISABLE /* Nested Interrupts Exit */ \
    __asm { LDMFD SP!, {LR} } /* Restore LR */ \
    __asm { MSR CPSR_c, #0x92 } /* Disable IRQ (IRQ Mode) */ \
    __asm { LDMFD SP!, {LR} } /* Restore SPSR_irq to LR */ \
    __asm { MSR SPSR_cxsf, LR } /* Copy LR to SPSR_irq */ \
    i got the following error.Can u suggest whats the problem??
    compiling irq2366.c...
    ..\Src\LowLevel\irq2366.c(250): error: #20: identifier "LR" is undefined
    ..\Src\LowLevel\irq2366.c(250): error: #20: identifier "SP" is undefined
    ..\Src\LowLevel\irq2366.c(250): warning: #1287-D: LDM/STM instruction may be expanded
    Thanks in Advance.
  • Haven't you asserted that
    my software hangs at PAbt_Addr DCD PAbt_Handler ?
  • sorry for previous one .
    #define I_Bit                   0x80
    #define F_Bit                   0x40
    #define SYS32Mode               0x1F
    #define IRQ32Mode               0x12
    #define FIQ32Mode               0x11
    static DWORD sysreg;            /* used as LR register */
    //#define IENABLE __asm { MRS sysreg, SPSR; MSR CPSR_c, #SYS32Mode }
    //#define IDISABLE __asm { MSR CPSR_c, #(IRQ32Mode|I_Bit); MSR SPSR_cxsf, sysreg }
    the above results in hanging.
    #define I_Bit                   0x80
    #define F_Bit                   0x40
    this results in hanging
  • keshan,
    how can anybody help you when you consistently fail to provide full details! now you posted commented code. post the implementation - how you USED there macros and where.
  • #define I_Bit                   0x80
    #define F_Bit                   0x40
    void PWMHandler (void) __irq
      DWORD regVal;
      IENABLE;                              /* handles nested interrupt */
      regVal = PWM0IR;
      if ( regVal & MR0_INT )
            match_counter0++;
      PWM0IR |= regVal;             /* clear interrupt flag on match 0 */
      regVal = PWM1IR;
            match_counter1++;
      PWM1IR |= regVal;             /* clear interrupt flag on match 0 */
      IDISABLE;
      VICVectAddr = 0;              /* Acknowledge Interrupt */
      return;
  • Hi Keshan,
    the macros you are trying to use to get nested interrupts don't really work. ARM provides a document called "Exception_Handling.ppt" which explains in detail how to handle nested interrupts.
    I can tell you that you can not use the compiler provided interrupt interface "__irq" to fulfill the ARM requirements. You may have to implement your own assembly interface for nested interrupts and write your high-level handlers in C or C++.
    Frank
