Are this devices compatible? May be some specific thing should be done to make them work together?
I have a problem, that my program which sends some data via ethernet works correctly on the Keil's MCB2368 board and did not works on device based on LPC2364 and 78Q2123. May be somebody know what it can be?
You can not use 78Q2123 device with LPC2364 because the 78Q2123 does NOT support RMII interface while LPC2364 ONLY supports RMII and not MII (See the errata sheet).
Franc
Thanks for your answer! May be you know, can lpc2366 or lpc2368 work with this 78Q2123?
