Hello, I've configured SPI bus on P0.2 (SCLK), P0.3(MISO), P0.4 (MOSI) and P0.5 (NSS) but on these ports: no signal. Normaly, I should have SPI clock at least but I have nothing.
I've configured :
1) Pins:
sbit SPI_SCLK=P0^2; // SPI clock on P0.2 sbit SPI_MISO=P0^3; // Master In/Slave Out on P0.3 sbit SPI_MOSI=P0^4; // Master Out/Slave In on P0.4 sbit SPI_NSS=P0^5; // Slave Select on P0.5
2) Ports:
void port_init (void) { char sfrpage_save = SFRPAGE; // Save current page of SFR SFRPAGE = CONFIG_PAGE; // Load config_page WDTCN = 0xde; WDTCN = 0xad; // Disable watchdog timer XBR0 = 0x02; // Enable SPI bus XBR1 = 0x00; // Enable /INT0 and /INT1 XBR2 = 0x40; // Enable Crossbar and weak pull-up P0MDOUT |= 0x3C; // P0.5, P0.4, P0.3 and P0.2 are outputs (for SPI datas) P0 = 0x3C; SFRPAGE = sfrpage_save; // Restore SFR page }
3) SPI bus:
void config_SPI (void) { char sfrpage_save = SFRPAGE; // Save current SFR page SFRPAGE = SPI0_PAGE; // Load SPI page SPI0CFG |= 0x40; // Master Mode Enable SPI0CN |= 0x8D; // Slave select and enable SPI SPI0CKR = 0x01; // SYSCLK/2 SFRPAGE = sfrpage_save; // Restore SFR page }
I have tried many times to resolve the problem but without satisfaction for the moment.
If you can help me, make it please. Thanks.
Manu
Or dynamicallocatiophilia...?
sticktolanguagephilia
"It must ALL be in C" or "It must ALL be in assembler"
Are you actually trying to USE the SPI when testing it? Can you post your current code?
If P0_2 = 1 works, that doesn't mean much. The system is laid out such that one of the last things is the port latches. The crossbar and the SPI controller are behind the port latches. In fact, attempting to directly set output pins that are being used for peripherals is probably not a good idea, no matter the chip.
If P0_2 = 1 works for the SILabs chips (at least for the f12x) it is clearly stated in the datasheet that when the crossbar assigns a pin to a 'device' (the SPI driver in this case) the port pin does not react to contents of the pprt latch.
Here is my source code:
NB: In the main routine, I always send data to observe the SPI clock to the oscilloscope.
//----------------------------------------------------------------------- // Includes //----------------------------------------------------------------------- #include <stdio.h> #include <c8051f120.h> // SFR declarations //----------------------------------------------------------------------- // Global constants //----------------------------------------------------------------------- sbit SPI_SCLK=P0^2; // SPI clock on P0.2 sbit SPI_MISO=P0^3; // Master In/Slave Out on P0.3 sbit SPI_MOSI=P0^4; // Master Out/Slave In on P0.4 sbit SPI_NSS=P0^5; // Slave Select on P0.5 //----------------------------------------------------------------------- // Functions prototypes //----------------------------------------------------------------------- void SYSCLK_Init (void); void port_init (void); void config_SPI (void); void transfert_donnees (int donnee); //----------------------------------------------------------------------- // Main //----------------------------------------------------------------------- void main (void) { int i; SYSCLK_Init (); port_init (); config_SPI (); SFRPAGE = SPI0_PAGE; // Load SPI page while (1) { transfert_donnees (0xAA); for (i = 0; i<256; i++); } } //---------------------------------------------------------------------- // SYSCLK_Init //---------------------------------------------------------------------- // // This routine initializes the system clock to use the internal oscillator // at 24.5 MHz multiplied by four using the PLL. // void SYSCLK_Init (void) { int i; // delay counter OSCXCN = 0x67; // start external oscillator with // 22.1184 MHz crystal for (i=0; i < 256; i++) ; // Wait for osc. to start up OSCICN = 0x88; // select external oscillator as SYSCLK // source and enable missing clock // detector } //----------------------------------------------------------------------- // Ports I/O initialisation //----------------------------------------------------------------------- void port_init (void) { char sfrpage_save = SFRPAGE; // Save current page of SFR SFRPAGE = CONFIG_PAGE; // Load config_page WDTCN = 0xde; WDTCN = 0xad; // Disable watchdog timer XBR0 = 0x06; // Enable SPI bus XBR1 = 0x14; // Enable /INT0 and /INT1 XBR2 = 0x40; // Enable Crossbar and weak pull-up P0MDOUT = 0x38; // P0.5, P0.4, P0.3 and P0.2 are outputs (for SPI datas) SFRPAGE = sfrpage_save; // Restore SFR page } //----------------------------------------------------------------------- // SPI bus configuration //----------------------------------------------------------------------- void config_SPI (void) { char sfrpage_save = SFRPAGE; // Save current SFR page SFRPAGE = SPI0_PAGE; // Load SPI page SPI0CFG |= 0x60; // Master Mode Enable SPI0CN = 0x0D; // Master mode; SPI enabled; SPI0CKR = 0x01; SFRPAGE = sfrpage_save; // Restore SFR page } //----------------------------------------------------------------------- // Data transfert //----------------------------------------------------------------------- void transfert_donnees (int donnee) { unsigned char donnee_1; unsigned char donnee_2; donnee_1 = ( donnee & 0xFF00) >> 8; // MSB in data_1 donnee_2 = ( donnee & 0x00FF); // LSB in data_2 while (TXBMT == 0); SPI0DAT = donnee_1; // data_1 transmission SPIF = 0; while (TXBMT == 0); SPI0DAT = donnee_2; // data_2 transmission SPIF = 0; }
PLEASE do not comment incorrectly, I were just about to post "your pinnings are wrong' when I realized that
XBR0 = 0x06; // Enable SPI bus is XBR0 = 0x06; // Enable UART0 and SPI bus
some of us will gladly help you, but if you make it more difficult to help you than need be such help will soon fade away.
Now, if you read the datasheet very carefully, you will find a little well hidden nugget which is that SPI must be initialized before the crossbar, since SPI init is the only place the (non)existence of NSS is known.
