I have few problems in working with i2c 1) How can I send data to EEPROM?(in arm core some status codes are available weather they have to give by our self or it will be generated automatically) 2)What this function I2C0MasterHandler() doing and when it will be called
I have included the source code here for irq handler Please clarify my doubts earlier
void I2C0MasterHandler(void) __irq { BYTE StatValue; /* this handler deals with master read and master write only */ StatValue = I20STAT; IENABLE; /* handles nested interrupt */ switch ( StatValue ) { case 0x08: /* A Start condition is issued. */ I20DAT = I2CMasterBuffer[0]; I20CONCLR = (I2CONCLR_SIC | I2CONCLR_STAC); I2CMasterState = I2C_STARTED; break; case 0x10: /* A repeated started is issued */ if ( I2CCmd == LM75_TEMP ) { I20DAT = I2CMasterBuffer[2]; } I20CONCLR = (I2CONCLR_SIC | I2CONCLR_STAC); I2CMasterState = I2C_RESTARTED; break; case 0x18: /* Regardless, it's a ACK */ if ( I2CMasterState == I2C_STARTED ) { I20DAT = I2CMasterBuffer[1+WrIndex]; WrIndex++; I2CMasterState = DATA_ACK; } I20CONCLR = I2CONCLR_SIC; break; case 0x28: /* Data byte has been transmitted, regardless ACK or NACK */ case 0x30: if ( WrIndex != I2CWriteLength ) { I20DAT = I2CMasterBuffer[1+WrIndex]; /* this should be the last one */ WrIndex++; if ( WrIndex != I2CWriteLength ) { I2CMasterState = DATA_ACK; } else { I2CMasterState = DATA_NACK; if ( I2CReadLength != 0 ) { I20CONSET = I2CONSET_STA; /* Set Repeated-start flag */ I2CMasterState = I2C_REPEATED_START; } } } else { if ( I2CReadLength != 0 ) { I20CONSET = I2CONSET_STA; /* Set Repeated-start flag */ I2CMasterState = I2C_REPEATED_START; } else { I2CMasterState = DATA_NACK; } } I20CONCLR = I2CONCLR_SIC; break; case 0x40: /* Master Receive, SLA_R has been sent */ I20CONCLR = I2CONCLR_SIC; break; case 0x50: /* Data byte has been received, regardless following ACK or NACK */ case 0x58: I2CMasterBuffer[3+RdIndex] = I20DAT; RdIndex++; if ( RdIndex != I2CReadLength ) { I2CMasterState = DATA_ACK; } else { RdIndex = 0; I2CMasterState = DATA_NACK; } I20CONSET = I2CONSET_AA; /* assert ACK after data is received */ I20CONCLR = I2CONCLR_SIC; break; case 0x20: /* regardless, it's a NACK */ case 0x48: I20CONCLR = I2CONCLR_SIC; I2CMasterState = DATA_NACK; break; case 0x38: /* Arbitration lost, in this example, we don't deal with multiple master situation */ default: I20CONCLR = I2CONCLR_SIC; break; } IDISABLE; VICVectAddr = 0; /* Acknowledge Interrupt */ }
