Hello all,
I'm using MDK-ARM Version 3.11. To generate a BIN-File from an AXF-File I'm using the tool "fromelf" of the ARM-MDK. I call this tool through the Option "Run User Programms after Build/Rebuild" of uVision.
After the AXF-File was created successfully "fromelf" returns with the following error message:
User command #1: C:\Keil\ARM\BIN31\fromelf.exe ".\Obj\NoApplication.axf" --bin --output ".\Obj\NoApplication.bin" Error: Q0108E: Could not create output file '.\Obj\NoApplication.bin_1': No such file or directory Finished: 0 information, 0 warning and 1 error messages.
I was able to address the issue to to following line of code:
volatile unsigned long gulBufferedRamFlag __attribute__((at(0xE0084000)));
When I remove the attribute, the generation of the BIN-File works.
I would be greatful for some hints...
Thanks in advance
Rainer
