SEND TEXT file with serial port
Dear All,
How do I send file on serial port?
Thanks in advance
Michele
  • AT Returns a "OK" to confirm that modem is working
    AT+CPIN="xxxx" To enter the PIN for your SIM ( if enabled )
    AT+CREG? A "0,1" reply confirms your modem is connected to GSM network
    AT+CSQ Indicates the signal strength, 31.99 is maximum.
    4. Sending SMS using AT commands
    We suggest try sending a few SMS using the Control Tool above to make sure your GSM modem can send SMS before proceeding. Let's look at the AT commands involved ..
    AT+CMGF=1 To format SMS as a TEXT message
    AT+CSCA="+xxxxx" Set your SMS center's number. Check with your provider.
    To send a SMS, the AT command to use is AT+CMGS ..
    AT+CMGS="+yyyyy" <Enter>
    > Your SMS text message here <Ctrl-Z>
  • What modem? Who said anything about a modem??
  • "4. Sending SMS using AT commands"
    SMS? Who said anything about sending SMS?
  • If you want to send a file from your computer to your microcontroller, use for example the HyperTerminal....then select transfer-->send text file
    This will send the file character by character.
    You can send any file, I use this to send my *.hex file when using a bootloader.
    In the configuration menu, inside ANSI options you can set the delay between characters and between new line.
    (Usefull when you send a big file and the buffer in the microcontroller is small)
  • The OP didn't say which direction the "file" was to be sent!
    I guess there must be at least a 50% chance that he wanted to send it from the PC to the microcontroller...
    In that case, it'd be easier to just do:
    COPY file COM1:
    "You can send any file"
    It would not be a good idea to send anything other than a text file this way...
