<bold>THIS IS VERY IMPORTANT SO YOU MUST READ PLEASE!</normal>
<italic>dear friends,</italy>
i got a project for ATMEL 89c51 I need to rotate the motor in forward and reverse directions with 2 micro switches. i am through with all the programming. i am going to use the ic L293D for supply reversal ok up to this its all fine with me..... ============= but the problem is, the motor is of 24 volts and 12AMP CAPACITY. i cant connect it with L293D ic.
what should i do now.... is there any other discrete H-BRIDGE circuit available or any ic, like l293d , to overcome this problem..?
the application is so simple in the nature but i am stuck with this hardware problem
PLEASE ADVISE, FRIENDS....
RONY.
<SMILEY>
Did your </normal>, <bold>, <italic>, </italy> codes work well in the preview?
How about using discrete transistors controlled by your chip? You should be able to find circuit descriptions for how to do it - did you look for application notes?
... current or voltage is Allegro Semiconductor
