Reprogramming full flash memory using IAP
Hi, i have problem using IAP to program full flash memory. I have found an example in the LPC INSIDE'R GUIDE but the Keil compiler can't compile. This is the code and the compiler output:
#include <LPC22xx.H>
typedef void (*IAP)(unsigned int [],unsigned int []);
IAP iap_bypointer;
void iap_byfunction (unsigned *cmd,unsigned *rslt,unsigned entry);
unsigned command[5];
unsigned result[5];
char Ram_Arry[] = "Hello World";
char *Ram_Pointer;
/////// LINE 13 ////////////
int main (void) __arm //Compile this in ARM instruction set
{ unsigned char index;
iap_bypointer = (IAP) 0x7FFFFFF1; //set IAP entry address in function pointer
//////////// LINE 19 /////////////////
Ram_Pointer = 0x40000100; //Set pointer to RAM
for (index = 0; index<0x0B; index++) //Copy data to be written to flash into the RAM
{ *Ram_Pointer = Ram_Arry[index];
Ram_Pointer++;
command[0] = 0x36; //command code for "Read part ID"
iap_byfunction(command,result,0x7FFFFFF0); //Call IAP functions by function method
command[0] = 50; //Prepare sector five for a write operayion
command[1] = 5;
command[2] = 5;
iap_bypointer(command,result);
command[0] = 51; //write 512 bytes from address 0x40000100
command[1] = 0x0000A000; //to 0x0000A000 in flash memory;
command[2] = 0x40000100;
command[3] = 512;
command[4] = 12000; // see erase comment above
while(1) {;}
///// LINE 45 //////
void iap_byfunction (unsigned *cmd,unsigned *rslt,unsigned entry) __thumb //compile this in Thumb instruction set
__asm { mov r15,r2; } //////// LINE 47 //////// //move entry address into PC
Build target 'Target 1'
assembling Startup.s...
compiling main.c...
main.c(13): error: #130: expected a "{"
main.c(19): error: #513: a value of type "int" cannot be assigned to an entity of type "char *"
main.c(45): error: #130: expected a "{"
main.c(47): error: #20: identifier "r15" is undefined
main.c(47): warning: #1267-D: Implicit physical register R2 should be defined as a variable
main.c(47): error: #549: variable "R2" is used before its value is set
Target not created
Can somebody please help me why the compiler can't do this if it's ok.
Thanks.
Yaque.
