I KEEP GETTING FATAL ERROR WHEN I TYPE A51 AT MY COMMAND LINE.
I GET TERMINATED.
WHY?
"anoyance of reading what you are typing in ALL CAPITALS"
Especially as it's been pointed out to you at least twice already!
1. The Keil A51 manual, to tell you how to correctly form an A51 command line;
2. The Ultraedit manual, to tell you how to get it to run a 3rd-party command line such as A51.
Note that uVision shows you the command options that it sets up - so, if you like GUIs and IDEs, you could try configuring your projuect in uVision first to tell you what command-line options to use!
See: http://www.keil.com/support/man/docs/uv3/uv3_dg_a51.htm (read the very last line of the text)
I TRY AND FAIL USING ULTEREDIT BCOZ I THINK THERE ARE TO MANY BUGS.
IVE BEEN TOLD THAT VS CODEWRITE ARE BETTER EDITOR. I SEE IF IT WORKS.
TANKS FOR YOUR SUPPORT.
Given your complete inablility to understand simple instructions like do not write in ALL CAPTALS, I very much doubt that this is anything to do with any inadequacy of the Ultraedit documentation - let alone bugs in the product!
"IVE BEEN TOLD THAT VS CODEWRITE ARE BETTER EDITOR."
I certainly like it - but I have no idea how it compares to Ultraedit, as I've never tried that.
"I SEE IF IT WORKS."
Yes, it does work. But you are still going to have to follow the same process of reading both manuals and following their instructions!
"IVE BEEN TOLD THAT VS CODEWRITE<sic> ARE BETTER EDITOR." I have never used Ultra Edit, but I can wouch for CodeWright not "CODEWRITE" being just great, I would use no other. When I change location, it is my first statement: "If you do not have a CodeWright for me, (I will not bootleg) order it"
PS Given your complete inablility to understand simple instructions If you persist in using CAPITALS, I will not try to help you any more.
But you will still have to do one more favor, Erik. You will have to scan through the manual for the page with the list of bugs in CodeWright - it shouldn't take too long until you get a request for it :)
I DONT KNOW CODEWRIGHT.
IT IS VS CODEWRITE THAT I AM GOING TO TRY. APERENTELEY IT IS FREE AND GOOD AND NOT SO BUGGED!
I LET YOU KNOW MY RESULT WHEN I TRY.
IF NO GOOD I LOOK AT CODEWRIGHT. BUT IT LOOKS VERY OLD AND EXPENSIFE I THINLK/.
TNANX FOR YOUR PHELP.
from my post before the garbage above Given your complete inablility to understand simple instructions If you persist in using CAPITALS, I will not try to help you any more.
PS all capitals does not become garbage till requests to desist are ignored
the story of CodeWright
a group of great people made an excellent editor called 'brief' (anyone remember that one?).
Borland got upset that so many stated that 'brief' was much better than the pitiful Borland editor and the solution was to buy the company that made 'brief' and discontinue 'brief'.
Some of the people from 'brief' then started to make CodeWright with all that 'brief' could and more.
Borland got upset that so many stated that CodeWright was much better than the pitiful Borland editor and the solution was to buy the company that made CodeWright and discontinue CodeWright.
That created such an uproar that Borland started shipping it again, but AFAIK they have now reverted to their old habits and discontinued it again.
PS: if you want the, in my opinion, best editor ever, Amazon has 3 left - hurry.
Erik,
I've been trying to ignore this quite bizarre thread, but you fired up my interest!
I remember Brief - Originally written by a company called UnderWare (or rather, at the time I bought a copy, it was them). I always thought the naming was a lovely pun!
For years, I've been wanting an editor that was as comfortable to use as Brief. I've tried quite a few: amongst them one called Crisp which has pretty good Brief emulation and recently SlickEdit which is not so good.
For a reason I can't remember, I decided not to follow up on CodeWright.
Question - Is it really as close to Brief as is suggested? By that, I mean, does it have very good emulation of the original Brief key combinations or does it approximate some?
David.
In conjunction with a job change I lost my beloved brief (I am an ardent non-bootlegger). Thus I started with CodeWright, oh how long ago was that?, using brief emulation for a while (I do not recall any problems). Then I worked with someone that used CodeWright in 'native mode' and, for fun, we did a couple of things with CodeWright and brief we actually found and used a copy of brief.
Even old dogs can learn new tricks and I switched to CodeWright in 'native mode' because I got convinced it was better (could do all brief could and more).
Since then I have only fond memories of brief and have forgotten more than I ever knew about it.
HI AGAIN,
I TRY VS CODEWRITE BUT IT HAS A BIG SERIOUS BUG! IT DOES NOT DO CODE FOL:DING.
ULTRAEDIT IS LESS BUGGED.
I TRY TO FIND CODEWRIGHT DEMO BUT NOT YET. HOPE IT IS NOT BUGGY.
HI POEPLE,
WHERE CAN I GET A DEMO COPY OF CODEWRIGHT. I DONT WANT TO PAY UNTIL I KNOW IT IS NOT SO BUGGED.
Use Notepad. It is free!
BUT NOTEPAD IS BUGED AS WELL. IT HAS NOT CODE FOLDING AND YOU CANNOT CALL A51 FROM INSIDE.
IS CODEWRIGHT ON TOOCOW?
