Problems with XDATA
I try to accces external Memory using XDATA.
I use the following code:
extern volatile unsigned char xdata interface_register _at_ 0x3;
This is the variable I want to acces, like this:
interface_register = 0x82;
Everything ok, so far.
But when I run the code in the simulator, it doesn't work. The compiler generated the following code(dissasembled):
40: interface_register = 0x82; // Interface konfigurieren: PA = Out, PB = IN, PC = OUT 41:
C:0x00FB 900000 MOV DPTR,#0x0000
C:0x00FE 7482 MOV A,#DPL(0x82)
C:0x0100 F0 MOVX @DPTR,A
So far as I can see, the Datapointer is not set correct. It should be set to 0x02. I can't find the problem.
The corresponding code from the listing is:
; SOURCE LINE # 27
0009 900000 MOV DPTR,#interface_register
000C 748B MOV A,#08BH
000E F0 MOVX @DPTR,A
The compiler used the # Operator to get the value of interface_register, to load it into DPTR. But why does the compiler use the # Operator? It should use the @ Operator to get the definend adress of interface_register (0x2).
Any suggestions? What did I do wrong?
