I'm using AT91EB55 evaluation board with MDK RealView compiler. If someone worked with this board and RV complier please write how to create scatter and startup file.
take a look to the folder: C:\Keil\ARM\Boards\Phytec\AT91M55800A
It is not the same Eval Board, but the same device. So using this as a starting point may help.
I've looked into Phytec board folder and many others as wall :) Simple programs like bilnky work propertly but the problem is that I'm trying to implement embOS on AT91EB55 and there is no example for further develop.
There are two choices: - talk to SEGGER about an EMBOS port - use RTX
