Hi
When using keil EPM900 emulator for debugging and clock setting as crystal high frequency (11.05mhz) my program execution is ok with the target board connected to EPM900.
But when I power up my flashed units (flashing using Flash magic) I am not getting clock input at XTAL1 PIN P3.1 to MCU means the MCU using some internal clock. I confirmed by removing the crystal from flashed unit and still my flashed unit is working but the timings were not right since it is not using the external crystal.
I am not using the START900.A51 where UCFG1 setting for external clock can be done as I could not able to re-flash my units when I use START900.A51 file.
This problem occured after I add the notouch code to my program to enable re-flashing. Before that my external clock working (11.05mhz) in flashed units was ok.
Thanks in advace Best Regards
