hello I'm working on the µC XC2267 for infineon. I don't find the XC2267 in option for target 'Device' in µvision3.
So to add this device in data base, I must adjust the CPU parameters for the XC2267
Just I've little problem when adding the new device in the option to adjusting the CPU parameters for the XC2267. Where can I find these parameters?
http://www.keil.com/support/man/docs/uv3/uv3_c_dd_parameters.htm
in the memory map of the XC2000, there are 3 sections for flash: Program Flash 0 : 0xC00000 - 0xC3EFFF, Program Flash 1 : 0xC40000 - 0xC7FFFF, Program Flash 2 : 0xC80000 - 0xCBFFFF,
there is a reserved sector for Program Flash0 from 0xC3F000 - 0xC3FFFF,
to adjusting the option of the cpu, we should mention the range of the flash IROM(0xC00000-???)
is it correct to put IROM(0xC00000-0xC3EFFF, 0xC40000-0xCBFFFF)
or I put IROM(0xC00000-0xCBFFFF)??
the problem that I found is in the reserved sector for the flash0
I hope that I explain well my problem now
