Differences in programming 8-bit ADC and 12-bit ADC
I am currently trying to modify an existing code to display 12 bit data (C8051F206) instead of 8 bit data (C8051F226).
When I download the existing codes and run the program, my LCD is able to display some values. However, when I modify the program to display 12 bit data, the LCD just show 0.000V when I adjusted the ADC input. May I know what is different in the ADC configuration that I have to change ? What is wrong with my 12 bit code?
8-bit code:
// Global CONSTANTS
        unsigned int q,value,temp;
        unsigned char a,b,c,d;
        float bit_value,result;
// ADC Conversion
void adcdata()
                ADCINT = 0;
                ADBUSY = 1;
                ldelay(100);
                while(ADCINT==0);
                value = ADC0L;
                value = value*256;
                ldelay(900);
                ldelay(1000);
                ADCINT=0;
                ADBUSY=0;
// Bit Resolution: result = Voltage reference*(255/256)
void bit_resolution()
        bit_value = 3.2/(256);
        result = value*bit_value;
My 12 bit code (Left justified ADCOH:ADCOL):
// Global CONSTANTS
        unsigned int q,value,value1,temp,totvalue;
        unsigned char a,b,c,d,e;
// ADC Conversion
void adcdata()
                ADCINT = 0;
                value=0;
                ADBUSY = 1;
                ldelay(100);
                while(ADCINT==0);
                value = ADC0L;
                e= 0x0F & ADC0H;
                value1=e;
                totvalue= value + value1*256;
                ldelay(900);
                ldelay(1000);
                ADCINT=0;
                ADBUSY=0;
Appreciate if anyone could help. Thanks!!
