Hi dazheng,
Need to know ... what is EEPROM used in MCU for ?. I know EEPROM stand for Electrical Erasable Programming ROM but I need to know what's the purpose or where it going to be used in MCU?
I ask this because some of MCU dont have EEPROM ( EEPROM = 0 byte) ie 80NC535 & 80NC321 and the best thing about this MCU (without EEPROM) that's its cheaper than MCU with EEPROM. If it just minor used and can solve it in other method (and not effect my project) , I will use it as I need to lower the cost as much as possible.
Any instruction (ie in proton) that must be used on MCU with EEPROM ?
More explanation greatly appreciated.
zuisti
"result is perfect. but sometimes it does not start"
This is clearly some new meaning of "perfect" of which we were previously unaware!
That's kind of "perfect in an imperfect sort of way", then?!
I'll tell the QA guys to stop being so negative - everything is "perfect", even if it doesn't work properly!
result is perfect. but sometimes it does not start Maybe they mean "complete" when saying perfect. This would explain why it does not start: It started some time ago and has ended now?
"Maybe they mean 'complete'"
As in, "complete nonsense" - like the rest of the thread...?
I'm dying to see the "machine" these two are trying to conjure up. Apparently it has something to do with an MP3 Player, a bathroom shower, and a CNC machine that is ok if it runs backwards.
This thread has to be a long-winded hoax...there just isn't any way two people can be this stupid!
R
That is what we hope, even if they are quite amusing.
"... a bathroom shower ..."
Plugged up by the very bushy sister that wears only tee-shirts who is such a bad cook that she gives her brother the datashits.
??? why the trollops keep trying to hyjack our project thread ???
i think we must use the secret code to hide detail or they will copy our ideas.
Ive gone back to the playa and want better snd.
I have a pair of unused 5.1 speakers. I was using them with my pc. I want now to use them with my 'television'. The problem to solve is: The speakers have two stereo inputs. One for low frequencies, one for middle rage frequencies and one for hight frequencies.
I want to design an active filter that will be able to split the stereo signal from my 'tv' to this three sections of frequencies.
Many years have passed since I was designing filters and I would like your help. i think we need mcu to do it better with lot more code for better sound. If there is a schematics out there it would be great.
plz.U hv to design active filter according to the frequency response of ur speakers. Then u will get excellent performance from ur filter. I hv one small swollen key filter design software but unable to upload here.
i know it is need for quick. but i know you are good strong profesional guru that helps again.
Thanks mate
... or they will copy our ideas. Hehe.
sorry for disturbing your delopment but i need more help v fat plz.
I also have have a small buzzer that emits many different sounds and, also, 3 error codes:
1) Bip Bip Bip at 440Hz 2) Biiip Biiip Biip at 700Hz 3) Biiiip Biiip Biiiip at 1150Hz 4) Biiiip Bip Biiip Biiiip at 1295Hz
I want to decode these 4 error codes. I can't touch nothing (the buzzer, the amp, the sound) than I must use a small little mic to capture the sound/code.
Besides, the buzzer is situated in a crowded place with many people that speaks, screams, cries etc.
Is it possible to do?
Thanks a lot and sorry, another time.
Where is this project going to be located?
Sounds like some sort of torture chamber!
A result of the high over-pressure in the showers.
Bip Bip Bip Biiiip Biiiip Biiiip Bip Bip Bip
"I want to design an active filter that will be able to split the stereo signal from my 'tv' to this three sections of frequencies."
An active filter is way overkill. Your speaker wire is stranded with a multiplicity of low, mid, and high frequency strands, each clearly marked if you look close enough. Many redundant 3-strands, but always a multiple of three.
Just separate out all the low frequency strands and connectorize them, then do the same for the mid and high frequency strands. Now you can connect your speakers accordingly.
Hi "zuisti",
i think about your err codes.very dificult for little MCU and we will need very poweful MCU with lots of speed code.
mayme you can use digital passband freq digital opamp but that is very hard.
you would appreciate links(?() to sites providing details regarding 'Multicycle Integrating Analog to Digital Converters'.
I believe these are meant for precision measurement applications requiring 20 - 24 bit precision. so i dont think 8 bit or 16 bit MCU is any good.you need 32 or more MCU bits.
maybe you need one MPU for each frequency(?) so it will cost a lot.
i am veeeery buzy now and have a lot of difficult project to complete. but i am happy to help my clever friend again.
"... i know you are good strong profesional guru ..."
This thread is proof counter to that.
