Is it possible to save the watch variables and its contents to a file using Keil Microvision ?
Thanks in Advance.
I Have no idea, I do not use uVision, just the compiler, assembler and linker ajnd dedicated tools (e.g. ICEs).
However, should those that have an idea reply "no you can not" do as I do from my ICEs: take a screenshot and print it.
not as far as I know. very annoying indeed!
why "save watches to a file" when you see something wrong in a watch, you act on it.
To Document acquisition parameteres.
You can put the watch varibles in a debug function then allocate the output to a com port or file. Look at debug commands like SLOG which creates a file of input and output from the Serial window. Also ASSIGN. there may be more.
Hope this helps.
"I Have no idea..."
Now there's a valuable response.
Just hope this is not the start of a habit or that others don't repeat it.
There again I might go to a forum on near anything, respond with I have no idea and people might think I'm an expert on the subject ;)
You can use the EValuate command to write into a log file...
say you have
unsigned int i_see_dead_people unsigned char str[ 10 ];
And you want to record them...
log >C:\Myval.TXT EValuate i_see_dead_people 0x000A 10 EV str[0] 0x52 82 EV str[1] 0x6F 110 log off
But the "Myval.TXT" file will only contain the numeric value ("0x000A 10"), and not the command you had entered ("EVALuate i_see_dead_people").
You could use the Display command instead (but you will have to manually specify the size):
D i_see_dead_people, i_see_dead_people+1 D:0x00 7A 03
But that can be tedious, so creating a 'batch file' with the needed DISPLAY commands and then including it and have that file generate the data for you:
The contents to the ReadMyVals.INI file LOG >C:\MyVals.TXT D i_see_dead_people, i_see_dead_people+1 D str, str[10] LOG OFF
Then in the uVision command line enter: >INCLUDE ReadMyVals.ini
(even the "D str, str[10]" command is now in the output file)
By becoming familiar with the command set that uVision has (or any Emulator/Simulator), you can create some fairly powerful tool sets.
During "Formal Qualification Testing" (FQT) of embedded software, there is often a need to capture the output of the data-stores in order to prove the validity of a function (e.g. "to document acquisition parameters.").
Once these type of test benches have been approved, you can automate the testing processes.
I've used these "INCLUDE" type batch files many times over. You can execute code up to a point ("g,Compute_What_Women_Want"), then modify the function's input data ("Flowers"), run the algorithm, and then write the output of the algorithm into a log file.
Then transfer that output file to the pre-approved/pre-qualified software for analysis to either tell you a PASS/FAIL, or some other qualifying criteria.
--Cpt. Vince Foster 2nd Cannon Place Fort Marcy Park, VA
He actually said, "I have no idea ... but..." (my emphasis) - and it was the "but" part that contains the (potentially) useful suggestion...
Thanks very much!
The use of the log and EVALuate commands are very usefull!
