Is it a known issue with uVision that it crashes whenever you try to debug Measure example by selecting Debug->Start/Stop Debug Session and then selecting Peripherals->A/D Converter? I checked on two different eval installations on W2Kpro and Win2003 Server. uVision build is 3.53
Well I've had the same problem like you do, so it is a known problem with more people.
"I've had the same problem"
Did you fix it? If so, how?
A known solution would be more useful than a known problem!
Solution: You need an updated simulator (part of next MDK release or write to support.intl@keil.com).
Is there anything anywhere that identifies this bug, and exactly what is affected, and what workarounds (if any) are available?
No I couldn't fix the problem either.
Only thing I know is that when you try to go in to debugger uVision 3 IDE crashes and quits.
Get an update or don't open the A/D dialog.
So the bug is in the "A/D dialogue", then?
