I downloaded the demo program from the website to measure the pulsewidth using TIMER0.
ET0 =1; EA =1; TMOD = (TMOD&0xF)| 0x09; //Set GATE0 bit while(1) { T0_ISR_count=0; TH0=0; TL=0; TR0=1; //start TIMER0 tdelay(200); //Test#1 //tdealay(500); //Test#2 while(!INT0); //wait for rising edge while(INT0); //wait for falling edge printf("The width pulse is: %ld uSec\n", (unsigned long) ((TH0<<8) | TL0 | ((unsigned long)T0_ISR_count<<16))); } } //------------------------ void tdelay(unsigned long I) //time delay { int i; for (i=0;I;i++); }
When I tested the code on the real board, changing from Test#1 to Test#2 (for tdelay function ) above made huge different results !!. I would think that the timer will not run until the INT0 goes HI because the SMOD bit4 (GATE0) is set. Could somebody kindly tell me what I did wrong here. NOTE: on the downloaded file, there was a PRINTF statement in replace of the tdelay(200) function. Again, I don't think it is going to make any different because the TIMER has not been fired yet at that line.
We are using Winbond 77LE532 (11.0592MHZ).
Jimmy
"I downloaded the demo program"
What demo program?
"from the website"
What website?
Provide a link, so that we can see the complete, unaltered example...
Here the example program I downloaded.
http://www.keil.com/download/docs/189.asp
Thanks,
JIMMY
