Hi all,
Please help .. I am coding program using KEIL's C51. My problem is at every build the build process start the coding from C:0x0800 address onwards. I want to change this location to C:0x0100. How I can do this?
Sham
"My problem is at every build the build process start the coding from C:0x0800 address onwards"
That'll be because you're using the free evauation, aren't you?
So it's not a "problem" - it is behaving exactly as described: http://www.keil.com/demo/limits.asp (C51 tools; 6th bullet point)
"How I can do this?"
Buy the full version!
http://www.keil.com/product/ordering.asp
Remember: nobody ever gives away a completely unrestricted version of any commercial product - there is always some limitation. Therefore you must always be sure to understand the limitations and/or restrictions before using any "free evaluation" of anything!
Thanks! we will order soon...
