ELF / AXF File change const variable values
I was wondering if there are any programs that allow the axf / elf file to be modified once it is generated.
I wish to insert manufactured date and serial number into the flash when the device is programmed. I thought the best way would be to read the axf file and insert the desired information into the memory locations allocated for it.
has anyone done this or has any suggestions
Thanks in advance.
