looking for better solution to struct offset
NOTE: C51
Keil uses 16 bit pointers and I have a file which is larger than 64k.
the file is a bunch of structures (all pointed to) that I acces as structures
This creates pure havoc when a structure crosses a 4k boundary.
example: at 0fffe
U16 shortvalue
U8 charvalue
if you access charvalue as str_pointer->charvalue, you get the contents of location 0, not 10000.
these values are NOT accessed by 'regular' code, but by U8 ReadFlash(U32 address)
any suggestions. The only one I have come up with is rather 'unpleasnt' i is to use #defines instead of structures
as in above example
#define shortvalue 0
#define charvalue 2
this makes [str_pointer->charvalue] into [str_pointer + charvalue] which the compiler treats 'correctly' as a 32 bit addition.
PS I have begged and begged the creator of these files to 'gap the files' where a 64k cross happens but get a "no way Jose"
  • A quick thought: if you can temporarily transform your C51 from big endian to little endian, when reading the section where it goes wrong...
    don't know if that is possible with this processor, though.
  • the file is a bunch of structures (all pointed to) that I acces as structures
    That doesn't seem to make sense. Either it's a file outside actual memory, or it's a C struct in memory. It can't be both.
    I'll assume you meant 64K boundary, because otherwise this makes no sense:
    example: at 0fffe
    U16 shortvalue
    U8 charvalue
    Well, it all depends on whatever it might be you're alluding to when you say "access as structures". You could of course use the "offsetof()" macro from stddef.h, but what you're really looking for would probably involve far pointers.
  • Hasn't it been mentioned that even far pointers barf on objects that cross a 64K boundary...?
    Possibly by Erik?
  • erik
    PS, I can see the reasoning for the 64k, the computation of memory locations for structure members would increase dramatically both in memory usage and computation time. And, I m sure it would ruin Keils benchmark comparisons to the competition. Also, I would nor want that overhead for 'normal' access. Thus, I am not objecting to using a workarond, just want to find the best one.
  • Thus, I am not objecting to using a workarond, just want to find the best one.
    Well, it's always terribly hard to discuss "the best" without first having a common ground of what to consider "good".
    Generally speaking, C data structures are neither meant to be directly mapped to data structures outside the program (e.g. on communication channels, or files), nor are they particularly useful for that purpose. From that point of view, #define'd offsets would be just the ticket.
    Otherwise, offsetof() should help.
  • Generally speaking, C data structures are neither meant to be directly mapped to data structures outside the program (e.g. on communication channels, or files), nor are they particularly useful for that purpose.
    'generally' you are right. However, in this case it is a bunch of structures that are used for display on a PC (while the user data (e.g. text strings, fonts) is entered) as well as for display on my signs to which they are downloaded after the user has finished entering.
    As a sidebar, I do net believe that "C data structures are meant to be" limited in size or dependent on location in memory.
  • As a sidebar, I do net believe that "C data structures are meant to be" limited in size or dependent on location in memory.
    But of course they are! They're limited in size at least by the addressable memory range of the processor. And they're dependent on location in memory inasmuch as they have to be located in memory. Your "file" isn't. It's on mass storage.
    If you're writing a program on a PC, you wouldn't expect to map the entire filesystem to a C datastructure, would you?
  • What kind of class would assign such a lame task or question?
    Well, almost. Memory-mapped files are quite often used for high-end solutions. And database servers are the main winners from the availability of 64-bit machines, since they need to be able to map structures larger than 4GB.
  • LOL
    Big oops. The quoted text was expected to be If you're writing a program on a PC, you wouldn't expect to map the entire filesystem to a C datastructure, would you?
  • But of course they are! They're limited in size at least by the addressable memory range of the processor.
    is the fact that I have an "addressable range" of 2MB for my flash chip invalid?
    It is NOT "on mass storage", it is loaded to a flash chip addressed as XDATA.
  • Turbo C implemented far and huge pointers, where the far pointer was a normal native pointer that could address a single 64kB block of data within a segment anywhere in memory.
    The huge pointer on the other hand was always normalized (having an offset in the [0..15] range) which allowed it to access structures of any size that could be fitted in memory.
    Keil really should have supplied two kinds of pointers, allowing the user to select the slow but general type, or the fast variant with the 64kB window limit.
  • is the fact that I have an "addressable range" of 2MB for my flash chip invalid?
    As long as that flash is not addressable by the MCU (i.e. it's not HDATA), it is invalid. Just because a rack-full of harddrives can address 500 TB doesn't mean a C program can handle C structs that large.
    2MB don't fit into 64KB, so that's obviously a misrepresentation of the facts.
  • The huge pointer on the other hand was always normalized (having an offset in the [0..15] range) which allowed it to access structures of any size that could be fitted in memory.
    Of any size? Yes.
    Of arbitrary position? No.
    Even Turbo C's huge pointers don't support objects straddling a 64 KiB boundary. Been there, done that.
  • Memory-mapped files are quite often used
    Files, yes. But not entire filesystems, precisely because they're larger than addressable memory.
    Which was my point, of course: a C program will have its own limits on object size, which have nothing to do with that of mass storage.
  • 2MB don't fit into 64KB, so that's obviously a misrepresentation of the facts.
    we are getting a bit off track here, the issue is not that (Keil) C should support it, but how to fetch it.
    Anyhow as to "obviously a misrepresentation of the facts" Keil DOES support "data banking" which, in it's way, makes the data address reange 24 bits.
    Again I am, in no form or fashion, stating Keil should process structures >64k and/or crossing page boundaries, just trying to find the 'safest' or, if you will, 'best' solution.
