Hi Group, I am using LPC2468 and wanted to store a file in the internal flash using RL-FlashFS and retrieve it back. The uVision Help says i need to focus on 3 modules and they are File_Config. c, FS_FlashPrg. c and FS_FlashDev. h.
I created the cutom FS_FlashDev. h with the uVisionHelp instruction and LPC_IAP2_512K ULINK FlashDev.c I created the custom FS_FlashPrg. c by modifying the LPC_IAP2_512K ULINK FlashPrg.c Ofcourse i did few modifications in File_Config. c With this custom files i created my TFTP server application and uploaded a file (yeah, initialized the RL-TCPNet Stack, formated the device, etc,). I get the "Transfer successfull" response.. But when i try to download the uploaded file, i get an error "Error on Server : File Not found"
I feel the there is a problem in writing into the internal falsh. So i am expecting some guidance in writing the above said 3 files for LPC2468 512KB flash (internal).
Thanks in advance
This is currently not possible for devices using ECC. LPC2468 is using ECC.
http://www.keil.com/forum/docs/thread9300.asp
